To create a data type based on both file name and location, include the name in the PATH_PATTERN value. You cannot use both NAME_PATTERN and PATH_PATTERN in the same criteria definition.
The QS_Source_Files data type defined below applies to all files named appn.c, where n= 1 through 9, located in subdirectories of */projects/QS.
DATA_ATTRIBUTES QS_Source_Files { ... } DATA_CRITERIA QS_Source_Files_Criteria { PATH_PATTERN */projects/QS/*/app[1-9].c DATA_ATTRIBUTES_NAME QS_Source_Files }
The following data type applies to all files in the directory /doc/project1 named chnn.xxx where n is 0 through 9, and xxx is any three-character file- name suffix.
DATA_ATTRIBUTES ChapterFiles { DESCRIPTION Chapter file for the project document. ICON chapter ACTIONS Edit,Print } DATA_CRITERIA Chapter_Criteria { PATH_PATTERN /doc/project1/ch[0-9][0-9].??? DATA_ATTRIBUTES_NAME ChapterFiles }
