Solaris Common Desktop Environment: Advanced User's and System Administrator's Guide
Syntax for the Database Search Path Input Variables
The syntax for the variables DTSPSYSDATABASEHOSTS and DTSPUSERDATABASEHOSTS is:
VARIABLE=location [,location...]
where location can have the syntax:
/path--specifies a directory on the local (session server) system. Use this syntax to add a local directory.
hostname:--specifies the system-wide directory /etc/dt/appconfig/types/language on system hostname.
hostname:/path--specifies a directory on the remote system hostname.
