The syntax for the variables DTSPSYSHELP
and DTSPUSERHELP
is:
VARIABLE=location [,location...]
where location can have the syntax:
/path--specifies a directory on the local (session server) system. Use this syntax to add a local directory.
To specify a location on another system, use its network file name--for example, /nfs/servera/projects/help.
