Each component in the Front Panel is defined separately using the syntax:
COMPONENT name { KEYWORD value KEYWORD value ... }
Some keywords are required, others are optional. For more information, see the dtfpfile(4X) man page.
The PANEL is the top-level component. Its definition includes:
The Front Panel name
Fields describing the general appearance and behavior of the entire Front Panel
PANEL front_panel_name { KEYWORD value KEYWORD value ... }
The front_panel_name is a unique name for the Front Panel. The default name is "FrontPanel."
A BOX definition describes:
The BOX name
The position of the box in the PANEL (POSITION_HINTS)
Fields describing appearance and behavior that apply to the entire box
BOX box_name { CONTAINER_NAME front_panel_name POSITION_HINTS position KEYWORD value KEYWORD value ... }
A CONTROL definition describes:
The CONTROL name
Whether the control is in a box, subpanel, or switch (CONTAINER_TYPE)
Which box, subpanel, or switch the control is in (CONTAINER_NAME)
The position of the CONTROL in the BOX (POSITION_HINTS).
Fields describing appearance and behavior of the control
CONTROL control_name { CONTAINER_TYPE BOX or SUBPANEL or SWITCH CONTAINER_NAME box_name or subpanel_name or switch_name TYPE control_type POSITION_HINTS position KEYWORD value KEYWORD value ... }
A SUBPANEL definition describes:
The SUBPANEL name
The name of the control to which the subpanel is attached (CONTAINER_NAME)
Fields describing appearance and behavior specific to the subpanel
SUBPANEL subpanel_name { CONTAINER_NAME control_name KEYWORD value KEYWORD value ... }
The SWITCH definition describes:
