The control definition's ICON field defines the icon image used for the control.
The value of the ICON field can be:
A base file name.
The base file name is the name of the file containing the icon image minus the file-name suffixes for size (m and t) and image type (bm and pm). For example, if files are named MyGame.l.pm and MyGame.m.pm, use MyGame.
If you use the base file name, the icon files must be placed in a directory on the icon search path:
Personal icons: HomeDirectory/.dt/icons
System-wide icons: /etc/dt/appconfig/icons/language
An absolute path to the icon file, including the full file name.
You should use the absolute path only if the icon file is not located on the icon search path.
The size icon you need depends on the location of the control:
Location Size
Main Panel - 48 by 48 pixels (name.l.pm or name.l.bm)
Subpanel - 24 by 24 pixels (name.s.pm or name.s.bm)
Place the icon file in one of these locations:
