The version 4 extensible data format is a new format supported by the CDE Calendar. The OpenWindows Calendar Manager will not be able to read this format. If you need to switch back and forth between the OpenWindows and CDE platforms, you should not convert your calendar to the version 4 data format. However, you can use the sdtcm_convert script to prune your calendar.
You can find out the data version of your calendar by choosing About Calendar from the Calendar Help menu.
Otherwise, use the sdtcm_convert script to convert your calendar to the version 4 data format.
For more information about this file, refer to the sdtcm_convert(1) man pages.
If you installed only the End User CDE Packages, the man pages were not installed. To see the man pages, you will need to install them with the pkgadd utility. .
