Solaris Common Desktop Environment: Advanced User's and System Administrator's Guide
Creating a Specialized Front Panel Control
In most cases, you do not need to provide a Front Panel control definition; the user can add the application to the Front Panel by dropping the action icon on the Install Icon control in a subpanel.
You might want to create a Front Panel configuration file containing a control definition for your application if you want users to be able to install a control that behaves differently than the action icon--for example, if the control monitors a file and changes appearance when the monitored file changes.
Front Panel configuration files are placed in the app_root/dt/appconfig/types/language directory. The naming convention is name.fp.
If you supply a configuration file containing a control, the user can add the control to a subpanel by dropping the *.fp file on the Install Icon control in the subpanel.
For example, the following definition can be placed in a Front Panel configuration file in the application group. If the user drops this file on an Install Icon control in a subpanel, a control is created in the subpanel that runs a single instance of the BestTextEditor application. If BestTextEditor is already running, the window is moved to the top of the window stack in the current workspace.
CONTROL BestTextEditorControl
 	TYPE						icon
 	ICON						BTEFPanel
 	PUSH_RECALL				True
 	CLIENT_NAME				BTEd
 	PUSH_ACTION				BTEditor
 	DROP_ACTION				BTEditor
 	HELP_STRING				Starts the BestTextEditor application.
For additional information about creating Front Panel configuration files, see:
