The default desktop configuration provides four workspaces. The user can add and delete workspaces using the pop-up menu associated with the Workspace switch.
The /usr/dt/app-defaults/C/Dtwm file has the workspaceCount resource set to the follwoing default number of workspaces:
Dtwm*0*workspaceCount: 4 Dtwm*workspaceCount: 1
Multiple workspaces are specified on screen 0. A single workspace is specified on any other screen.
You can create (or modify if it exists) the /etc/dt/config/C/sys.resources file to change the default number of workspaces for all new users on a workstation.
Use the 0*workspaceCount resource to set the system wide default on the primary screen:
Dtwm*0*workspaceCount: number
For example, the following resource sets the number of workspaces system wide on the primary screen to six:
Dtwm*0*workspaceCount: 6
For information about setting Workspace Manager resources, see"Setting Application Resources" .
For example, the following resource sets the number of workspaces to six:
Dtwm*workspaceCount: 6
