OpenWindows User's Guide
Application
The Application text field defines the application that is invoked whenever any file defined by the current binding is opened in File Manager or other applications in the DeskSet environment. This text field is on the expanded portion of the Icon Properties window.
Note -
If there is a ToolTalk method available, applications do not use this field. Refer to the Desktop Integration Guide.
