Use the Pattern text field beneath the scrolling list to modify the name of a File Type entry. If the files are to be identified by a pattern, this pattern must be the name of the Binding entry. If the currently selected File Type is identified by Content, the Pattern text field is dimmed and unavailable.
When there are no items selected on the scrolling list, you can type a pattern into the Pattern text field and press Return to create a new File Type entry.
