OpenWindows User's Guide
Keyboard Menu Equivalents
You can turn on or turn off the keyboard accelerator keys. This means that the keyboard character of the acceleration shows up in the following:
This is a standard set of tasks (within a DeskSet application) that can be "accelerated" from the keyboard by using keyboard shortcuts. These will be visible from the pull-down menus, and can be configured on or off from the Workspace Properties menu. Keyboard accelerators are active for only the windows that are active. If you need to turn these off, you can select None from Keyboard Menu Equivalents from the Keyboard Properties. The following table outlines the keyboard shortcuts and their functions.
Note -
The Meta key is the <> key on SPARC keyboards; on x86 and PowerPC keyboards Meta is obtained by pressing Ctrl-Alt.
Table Legend
The following table uses these abbreviations:
Table 17-1 Keyboard Equivalent Menu Items
Accel
FM
CM
MT
TE
SS
IE
B
PT
IT
AT
Copy
Meta - c
X
X
X
X
X
Cut
Meta - x
X
X
X
X
X
Find
Meta - f
X
X
X
X
New
Meta - n
X
X
X
Open
Meta - o
X
X
X
X
btn
X
X
X
Paste
Meta - v
X
X
X
X
Print
Meta - p
X
X
X
X
X
X
Props
Meta - i
X
X
X
X
X
X
X
Redo
Shift- Meta - p
X
X
Save
Meta - s
X
X
btn
X
btn
X
X
Sel.All
Meta - a
Undo
Meta - u
X
X
X
X
Typeface
Meta - t
Normal
Shift- Meta - n
Bold
Shift- Meta - b
Italic
Shift- Meta - i
