Tape device names are not automatically included in your system configuration unless a tape drive is hooked up at the time of installation.
If you add a tape driver after the inital system installtion but did not reboot your system afterwards, you will get this error message. To reconfigure your system to include the new tape device name, shut down your system and reboot with the following flags:
