OpenWindows User's Guide
Editing the Command Line
In the Command Tool, the command line can be edited. You can move the pointer to any location on the command that you have typed and click SELECT to position the insert point there. You can then type in that location or erase the previously typed characters and retype that portion of the command. Figure 6-3 shows the insert point.
Figure 6-3 Insert Point in a Command Line
Graphic
