When you have listed the files from a tape, choosing Entire List from the Read menu reads the entire list of files from the Tape Contents window.
When you have not listed the contents of a tape, choosing Entire List displays the Tape Contents window without a listing.
While the files are being read, messages are displayed in the footer of the Tape Tool window showing you the percentage of files that have been read. As the files are read, they are removed from the Tape Contents window. When the process is complete, a message is displayed in the footer of the Tape Tool window telling you how many files were read.
If there are a large number of files, it may take several minutes for the files to be copied to your system.
