OpenWindows Advanced User's Guide
2.2.1 Correcting Typing Mistakes
Suppose you started to type Date, but then realized your mistake before pressing the Return key. The text you type is not sent to the system until you press Return. Therefore, it is still possible to correct your mistake. You have two choices:
Try both of these and see how they work. (The Delete/Backspace key varies on some systems. Ctrl-U should work on most systems.)
