The default font for windows is Lucida Sans in 12 point (medium); the default font for window headers is Lucida Sans Bold. If you prefer, you can specify another font style and size for windows and window headers. You can make the change for a single window or you can make a permanent change for all your applications with Workspace Properties. The following subsections describe each of these options.
Note that there are two general categories of fonts--fixed-width and proportionally-spaced. Each character in a fixed-width font takes up the same amount of space as every other character. By contrast, the characters in a proportionally-spaced font require varying amounts of space, depending upon their individual width. Proportionally-spaced fonts are more pleasing to the eye. However, some applications (such as Command Tool, Shell Tool, and xterm, a popular terminal emulator application) work best with fixed-width fonts.
Note that the default font displayed in Command Tool and Shell Tool is a proportionally-spaced font. Although this font is pleasing to the eye, problems occur in character alignment (when spacing and tabbing) with any proportionally-spaced font in terminal windows. If the spacing and tabbing character alignment are a problem for you, it is best to choose a fixed-width font for these windows. In the examples that follow, only fixed-width fonts are used for terminal windows; the examples for other windows and headers use proportionally-spaced fonts.
This section describes how to open a single application with a modified font style and point size. Note that changes cannot be made to existing windows; you must start a new application to display the new font. To start a new application, you type its application name on a command line.
The basic command, shown below, specifies the application name, the -fn (font name) option, and the font style and size. The ampersand (&) returns your system prompt to the window after you type the command; this enables you to continue using that window.
$ application -fn fontstyle-pointsize & |
The following are examples of how to use the command to open an application with a specified font style and size.
The example below starts a new Command Tool with the proportionally-spaced font, Lucida Sans Typewriter Bold.
The point size is not specified; therefore the default (12-point) is used.
$ cmdtool -fn lucidasans-typewriter-bold & |
The example below starts a new Shell Tool with Lucida Sans Typewriter Bold and increases the size of the font from 12 point to 14 point.
Note that when you change the size of the font, the size of the window changes as well.
$ shelltool -fn lucidasans-typewriter-bold-14 & |
The example below starts a new xterm terminal window with the font terminal-bold in 16 point:
$ xterm -fn terminal-bold-16 & |
The example below starts a new Text Editor with the font Helvetica Bold in 14 point:
$ textedit -fn helvetica-bold-14 & |
Use the -fn option with any application and any font style and size you choose. "10.4.2.1 The Available Font List" describes how to list all the fonts available for OpenWindows applications.
If you find that you are repeatedly running applications with customized fonts, you might like to add the customization to your workspace menu. You can do this using the Programs Menu category of Workspace Properties. This will save you the effort of typing the command-line options every time. For example, if you often want to run the text editor with a larger point size, you could add the following command line to the programs menu:
textedit -fn lucidasans-typewriter-14 |
You can have more than one instance of the same application in your programs menu if you want them to have different font sizes. This is useful if you run an application at a variety of different point sizes. For instance, you may want to have the option of running a text editor using 12, 14, or 18 point fonts. You would add the following commands to your programs menu:
textedit -fn lucidasans-typewriter-12 textedit -fn lucidasans-typewriter-14 textedit -fn lucidasans-typewriter-18 |
Once you have customized your programs menu from Workspace Properties in this way, you can invoke the text editor at any of these point sizes simply by selecting the appropriate item from your programs menu.
Command lines added to the programs menu should not be followed by an ampersand (&).
