Suppose you want to find lines in the text that have a dollar sign ($) in them. Preceding the dollar sign in the regular expression with a backslash (\) tells grep to ignore (escape) its special meaning. This is true for the other metacharacters (& ! . * ? and \ itself) as well.
For example, the expression
$ grep ^\. |
matches lines starting with a period, and is especially useful when searching for nroff or troff formatting requests (which begin with a period).
The following table, Table 4-1, provides a list of the more commonly used search pattern elements you can use with grep.
Table 4-1 grep Search Pattern Elements|
Character |
Matches |
The beginning of a text line |
The end of a text line |
Any single character |
Any single character in the bracketed list or range |
Any character not in the list or range |
Zero or more occurrences of the preceding character or regular expression |
Zero or more occurrences of any single character |
Escapes special meaning of next character |
Note that these search characters can also be used in vi text editor searches.
