! ! nolefty.data ! ! Data for xmodmap to reset the left and right function keys ! after being set for left-handed use on the Sun type-4 keyboard. ! To use this data, type the following where <filename> is the name ! of the file. ! ! xmodmap <filename> ! ! Reassign standard values to left function keys. ! keycode 10 = L2 L2 SunAgain keycode 32 = L3 L3 SunProps keycode 33 = L4 L4 SunUndo keycode 56 = L5 L5 SunFront keycode 58 = L6 L6 SunCopy keycode 79 = L7 L7 SunOpen keycode 80 = L8 L8 SunPaste keycode 102 = L9 L9 SunFind keycode 104 = L10 L10 SunCut ! ! Reassign standard values to right function keys. ! keycode 28 = R1 R1 Pause keycode 29 = R2 R2 Print keycode 30 = R3 R3 Scroll_Lock Break keycode 52 = R4 R4 KP_Equal keycode 53 = R5 R5 KP_Divide keycode 54 = R6 R6 KP_Multiply keycode 75 = R7 R7 KP_7 Home keycode 77 = R9 R9 KP_9 Prior keycode 98 = Left R10 KP_4 keycode 100 = Right R12 KP_6 keycode 119 = R13 R13 KP_1 End keycode 121 = R15 R15 KP_3 Next ! ! Reassign the Linefeed key as such and remove from control map. ! remove control = Control_R keycode 118 = Linefeed
