To delete the .xinitrc file from your home directory, type the following command:
$ rm .xinitrc |
To retain the changes to your .xinitrc file, do the following steps:
Move .xinitrc to .xinitrc.save:
$ mv .xinitrc .xinitrc.save |
Copy /usr/openwin/lib/Xinitrc to .xinitrc in your home directory:
$ cp /usr/openwin/lib/Xinitrc $HOME/.xinitrc |
Add the lines that you want to keep from the .xinitrc.save to .xinitrc.
When editing the .xinitrc file, do not add a secondary version of olwm, do not add svenv, and do not remove the line containing /usr/openwin/lib/openwin-sys.
