10.5.5.3 Puck Connection
Puck connection errors indicate a communication problem with Calibrator Tool and the calibration puck. You may not have the puck connected firmly in a port or connected to the correct port.
x86 only - The puck must be connected to port 1.
The following puck connection error messages tell you to check that the calibrator is plugged in firmly to either serial port A or serial port B of your workstation:
Calibrator Tool is not functioning properly
Unable to get a response from the puck
Unable to read the puck version number
Unable to get the puck sensitivity value
Unable to set the puck sensitivity value
Unable to get the puck integration time
Unable to get the puck refresh fields value
Unable to set the puck averaging value
Module was unable to perform successful luminance data measurement
