D.2.1 Who Should Read this Section
The default security configuration in the OpenWindows Version 3.3 software, or later versions, does not need to be changed unless you run applications in any of the following configurations:
You run an application linked with versions of Xlib or libcps older than the OpenWindows Version 2 software or X11R4.
You run an application that is statically linked to OpenWindows Version 2 libraries and you want to use the SUN-DES-1 authorization protocol.
You run an application on a remote server.
