The client authority file is .Xauthority. It contains entries of the form:
connection-protocol auth-protocol auth-data |
By default, .Xauthority contains MIT-MAGIC-COOKIE-1 as the auth-protocol, and entries for the local display only as the connection-protocol and auth-data. For example, on host anyhost, the .Xauthority file may contain the following entries:
anyhost:0 MIT-MAGIC-COOKIE-1 82744f2c4850b03fce7ae47176e75localhost:0 MIT-MAGIC-COOKIE-1 82744f2c4850b03fce7ae47176e75anyhost/unix:0 MIT-MAGIC-COOKIE-1 82744f2c4850b03fce7ae47176e75 |
When the client starts up, an entry corresponding to the connection-protocol is read from .Xauthority, and the auth-protocol and auth-data are sent to the server as part of the connection packet. In the default configuration, xhost returns empty host-based access lists and state that authorization is enabled.
If you have changed the authorization protocol from the default to SUN-DES-1 the entries in .Xauthority contain SUN-DES-1 as the auth-protocol and the netname of the user as auth-data. The netname is in the following form:
unix.userid@NISdomainname |
For example, on host, anyhost the .Xauthority file may contain the following entries, where unix.15339@EBB.Eng.Sun.COM is the machine-independent netname of the user:
anyhost:0 SUN-DES-1 "unix.15339@EBB.Eng.Sun.COM" localhost:0 SUN-DES-1 "unix.15339@EBB.Eng.Sun.COM" anyhost/unix:0 SUN-DES-1 "unix.15339@EBB.Eng.Sun.COM" |
If you do not know your network name, or machine independent netname, ask your system administrator.
