Type:
% cd directory |
where directory is the name of the directory in which the files that you want to copy are located.
For example, to copy the file /home/samples/design, type:
% cd /home/samples |
Type:
% tar cvf device_name filename |
Table G-4 tar Command Options to Copy Files to a PCMCIA Memory Card
Option |
Description |
creates a backup archive |
displays a verbose listing |
specifies an input device name |
For example, to copy the file ./design located on your hard disk to a PCMCIA memory card that has the device name /dev/rdsk/c1t6d0s2, type:
% tar cvf /dev/rdsk/c1t6d0s2 ./design |
