Application Packaging Developer's Guide
The patch_postinstall Script
# This script deletes the used backout data for a patch package
# and removes the deletes file entries.
# directory format options.
#       @(#)patch_postinstall 1.2 96/01/29 SMI
# Copyright (c) 1995 by Sun Microsystems, Inc.
# All rights reserved
PATH=/usr/sadm/bin:$PATH
THIS_DIR=`dirname $0`
Our_Deletes=$THIS_DIR/deletes
# Delete the used backout data
if [ -f $Our_Deletes ]; then
        cat $Our_Deletes | while read path; do
                if valpath -l $path; then
                        Client_Path=`echo "$CLIENT_BASEDIR/$path" | sed s@//@/@`
                else    # It's an absolute path
                        Client_Path=$path
                fi
                rm `removef $PKGINST $Client_Path`
        done
        removef -f $PKGINST
        rm $Our_Deletes
fi
# Remove the deletes file, checkinstall and the postinstall
rm -r $PKGSAV/$ACTIVE_PATCH
rm -f $THIS_DIR/checkinstall $THIS_DIR/postinstall
exit 0
