LPDEST
Uses the specified value as the printer destination
for the file. If the variable is not set, the default printing device for your application should be used.
DTPRINTUSERFILENAME
Specifies the name of the file as it should appear in the Print dialog or print output. If the variable is not set, the actual file name should be used.
DTPRINTSILENT
Specifies whether to display a Print dialog box. When the variable is set to True, the Print dialog should not be displayed. If the variable is not set, the dialog box should be displayed.
DTPRINTFILEREMOVE
When the variable is set to True, the file should be removed after it is printed. This functionality is intended for temporary files that don't need to be retained after printing is complete. If the variable is not set, the file should not be removed.
