The CSA interface provides several calendar management functions. The CDE implementation supports multiple calendars per calendar service; the calendar-enabled application can add or delete calendars. The csa_delete_calendar() function is used to delete calendars. The csa_add_calendar() function is used to add new calendars to the service.
The application can also list, read, and update calendar attributes using the csa_list_calendar_attributes(), csa_read_calendar_attributes(), and csa_update_calendar_attributes() functions. The application can register callback functions for receiving notification of a calendar logon, calendar deletion, update of calendar attributes, addition of a new calendar entry, deletion of a calendar entry, and update of a calendar entry. The callback function is only registered for the duration of the calendar session. In any case, this information may be invaluable for some calendar administration applications.
