To Look Up Entries in a Calendar
Example 10-7 Looking up Calendar Entries; Reading Attribute Values
#include <csa/csa.h>
CSA_return_code stat;
CSA_session_handle cal;
CSA_attribute attrs[4];
CSA_attribute_value attr_val[4];
CSA_enum ops[4];
CSA_uint32 i;
CSA_uint32 num_entries;
CSA_entry_handle *entries;
CSA_uint32 num_attributes;
CSA_attribute *entry_attrs;
/* find all entries with the following criteria:
* (all appointments in the month of August 1996 UTC time)
* start date equals to or after 00:00:00 Aug 1 1996 UTC time
* and start date before 00:00:00 Sep 1 1996 UTC time
* and type equals to CSA_TYPE_EVENT
* and sub-type equals CSA_SUBTYPE_APPOINTMENT
i = 0;
/* start date equals to or after 00:00:00 Aug 1 1996 UTC time */
attrs[i].name = CSA_ENTRY_ATTR_START_DATE;
attrs[i].value = &attr_val[i];
attrs[i].attribute_extensions = NULL;
attr_val[i].type = CSA_VALUE_DATE_TIME;
attr_val[i].item.date_time_value = "19960801T000000Z";
ops[i] = CSA_MATCH_GREATER_THAN_OR_EQUAL_TO;
i++;
/* start date before 00:00:00 Sep 1 1996 UTC time */
attr_val[i].item.date_time_value = "19960901T000000Z"
ops[i] = CSA_MATCH_LESS_THAN;
i++;
/* type equals to CSA_TYPE_EVENT */
attrs[i].name = CSA_ENTRY_ATTR_TYPE;
attr_val[i].type = CSA_VALUE_UINT32;
attr_val[i].item.sint32_value = CSA_TYPE_EVENT;
ops[i] = CSA_MATCH_EQUAL_TO;
i++;
/* sub-type equals CSA_SUBTYPE_APPOINTMENT */
attrs[i].name = CSA_ENTRY_ATTR_SUBTYPE;
attr_val[i].type = CSA_VALUE_STRING;
attr_val[i].item.string_value = CSA_SUBTYPE_APPOINTMENT;
i++;
/* do look up */
stat = csa_list_entries(csa, i, attrs, ops, &num_entries, &entries, NULL);
if (stat == CSA_SUCCESS) {
for (i = 0; i < num_entries; i++) {
/* get all attribute values of the entry;
* specifying 0 for number_names and NULL for attribute_names
* will cause all attribute values to be returned
stat = csa_read_entry_attributes(cal, entries[i], 0, NULL,
&num_attributes, &entry_attrs,
NULL); if (stat == CSA_SUCCESS) {
/* use the returned attribute values,
* free the memory when done
csa_free(entry_attrs);
} else {
/* handle error */
} else {
/* handle error */
Example: Change the end time of the returned appointments to be
one hour later.
CSA_attribute_reference name = CSA_ENTRY_ATTR_END_DATE;
char buffer[80];
time_t endtime;
CSA_entry_handle new_entry;
/* get the end time of the appointment */
stat = csa_read_entry_attributes(cal, entries[i], 0, &name,
&num_attributes, &entry_attrs, NULL);
/* change the end time to be one hour later */
from_iso8601_time(entry_attrs[0].value->item.date_time_value, &endtime);
endtime += 60*60 /* number of second in an hour */
to_iso8601_time(endtime, buffer);
attrs[0].name = CSA_ENTRY_ATTR_END_DATE;
attrs[0].value = &attr_val[i];
attrs[0].attribute_extensions = NULL;
attr_val[0].type = CSA_VALUE_DATE_TIME;
attr_val[0].item.date_time_value = buffer;
stat = csa_update_entry_attributes(cal, entries[0], CSA_SCOPE_ALL,
CSA_FALSE, 1, attrs, &new_entry,
NULL);
csa_free(new_entry);
} else {
/* handle error */
} else {
/* handle error */
