The set of standard application default font names is defined by the XLFD field name values described in Table 2-2 .
Table 2-2 Field Name Values for Standard Application Font Names
Field |
Value |
Description |
FOUNDRY |
dt |
CDE name |
FAMILY_NAME |
application |
CDE standard application font name |
WEIGHT_NAME |
medium or bold |
Weight of the font |
SLANT |
r i |
Roman Italic |
SET_WIDTH |
normal |
Normal set width |
ADD_STYLE |
sans serif |
Sans serif font Serif font |
PIXEL_SIZE |
Platform dependent |
POINT_SIZE |
pointsize |
Point size of the desired font |
RESOLUTION_X |
RESOLUTION_Y |
AVERAGE_WIDTH |
p m |
Proportional Monospace |
NUMERIC FIELD |
CHAR_SET_REGISTRY |
iso8859-1 |
Defining standards authority |
ENCODING |
1 |
Character set number |
The standard names are available using the regular X Windows XLFD font- naming scheme. When properly specified with appropriate wildcards for the platform-dependent fields, a CDE font name is guaranteed to open a valid, corresponding platform-dependent font. The XLFD name returned from a call to the Xlib XListFont function, however, is not guaranteed to be the same on all CDE platforms.
Using these values, the XLFD pattern
-dt-application-*
matches the full set of CDE standard application font names on a given platform. The pattern
-dt-application-bold-*-*-*-*-*-*-*-p-*-*-*-
matches the bold, proportionally spaced CDE fonts, both serif and sans serif. And the pattern
-dt-application-*-*-*-*-*-*-*-*-m-*-*-*-
matches the monospaced fonts (whether serif or sans serif, or both).
The full set of CDE Standard Application Font Names can be represented as follows:
-dt-application-bold-i-normal-serif-*-*-*-*-p-*-iso8859-1 -dt-application-bold-r-normal-serif-*-*-*-*-p-*-iso8859-1 -dt-application-medium-i-normal-serif-*-*-*-*-p-*-iso8859-1 -dt-application-medium-r-normal-serif-*-*-*-*-p-*-iso8859-1 -dt-application-bold-i-normal-sans-*-*-*-*-p-*-iso8859-1 -dt-application-bold-r-normal-sans-*-*-*-*-p-*-iso8859-1 -dt-application-medium-i-normal-sans-*-*-*-*-p-*-iso8859-1 -dt-application-medium-r-normal-sans-*-*-*-*-p-*-iso8859-1 -dt-application-bold-i-normal-*-*-*-*-*-m-*-iso8859-1 -dt-application-bold-r-normal-*-*-*-*-*-m-*-iso8859-1 -dt-application-medium-i-normal-*-*-*-*-*-m-*-iso8859-1 -dt-application-medium-r-normal-*-*-*-*-*-m-*-iso8859-1 -dt-application-medium-r-normal-*-*-*-*-*-p-*-dtsymbol-1
