The DtEditor input/output functions are described in Table 7-4 .
Table 7-4 DtEditor Input/Output Functions|
Function |
Description |
DtEditorAppend |
Appends content data to the end of an editor widget. |
DtEditorAppendFromFile |
Appends the contents of a file to the end of an editor widget. |
DtEditorGetContents |
Retrieves the entire contents of an editor widget. |
DtEditorInsert |
Inserts content data at the current insert position. |
DtEditorInsertFromFile |
Inserts the contents of a file at the current insert position. |
DtEditorReplace |
Replaces a portion of text with the supplied data. |
DtEditorReplaceFromFile |
Replaces a portion of text with the contents of a file. |
DtEditorSaveContentsToFile |
Saves the entire contents to a file. |
DtEditorSetContents |
Loads content data into an editor widget, replacing the entire contents of the widget. |
DtEditorSetContentsFromFile |
Loads the contents of a file into an editor widget, replacing the entire contents of the widget. |
