Solaris Common Desktop Environment: Programmer's Guide
Resources
The DtEditor widget provides the following set of resources.
The status line also includes a Motif XmTextField(3X) widget for displaying messages supplied by an application. This field is a convenient place for an application to display status and feedback about the document being edited. The ID of the text field is retrieved using DtEditorGetMessageTextFieldID(3). A message is displayed by setting the XmNvalue or XmNvalueWcs resource of this widget. If the text field is not needed, you can unmanage it by calling XtUnmanageWidget(3X) with its ID.
Table 7-9 lists the class, type, default, and access for each resource. You can also set the resource values for the inherited classes to set attributes for this widget. To reference a resource by name or class in an .Xdefaults file, remove the DtN or DtC prefix and use the remaining letters. To specify one of the defined values for a resource in an .Xdefaults file, remove the Dt prefix and use the remaining letters (in either lowercase or uppercase, but include any underscores between words).
The codes in the access column show if you can:
See the DtEditor(3) man page for more information.
Table 7-9 DtEditor Resources
Name
Class
Type
Default
Access
DtNautoShowCursorPosition
DtCAutoShowCursorPosition
Boolean
True
CSG
DtNblinkRate
DtCBlinkRate
int
500
CSG
DtNbuttonFontList
DtCFontList
XmFontList
Dynamic
CSG
DtNcolumns
DtCColumns
XmNcolumns
Dynamic
CSG
DtNcursorPosition
DtCCursorPosition
XmTextPosition
0
CSG
DtNcursorPositionVisible
DtCCursorPositionVisible
Boolean
True
CSG
DtNdialogTitle
DtCDialogTitle
XmString
NULL
CSG
DtNeditable
DtCEditable
Boolean
True
CSG
DtNlabelFontList
DtCFontList
XmFontList
Dynamic
CSG
DtNmaxLength
DtCMaxLength
int
Largest integer
CSG
DtNoverstrike
DtCOverstrike
Boolean
False
CSG
DtNrows
DtCRows
XmNrows
Dynamic
CSG
DtNscrollHorizontal
DtCScroll
Boolean
True
CG
DtNscrollLeftSide
DtCScrollSide
Boolean
Dynamic
CG
DtNscrollTopSide
DtCScrollSide
Boolean
False
CG
DtNscrollVertical
DtCScroll
Boolean
True
CG
DtNshowStatusLine
DtCShowStatusLine
Boolean
False
CSG
DtNspellFilter
DtCspellFilter
char *
Spell
CSG
DtNtextBackground
DtCBackground
Pixel
Dynamic
CSG
DtNtextDeselectCallback
DtCCallback
XtCallbackList
NULL
C
DtNtextFontList
DtCFontList
XmFontList
Dynamic
CSG
DtNtextForeground
DtCForeground
Pixel
Dynamic
CSG
DtNtextTranslations
DtCTranslations
XtTranslations
NULL
CS
DtNtextSelectCallback
DtCCallback
XtCallbackList
NULL
C
DtNtopCharacter
DtCTextPosition
XmTextPosition
0
CSG
DtNwordWrap
DtCWordWrap
Boolean
True
CSG
