The following list describes a set of widget resources that are designed for localization of the DtEditor widget and its dialog boxes. Default values for these resources depend on the locale.
DtNcenterToggleLabel specifies the label for the center alignment toggle button in the Format Settings dialog box. The default value in the C locale is Center.
DtNchangeAllButtonLabel specifies the label for the button in the Find/Change dialog box that changes all occurrences of the Find string in the document. The default value in the C locale is Change All.
DtNchangeButtonLabel specifies the label for the button in the Find/Change dialog box that changes the next occurrence of the find string in the document. The default value in the C locale is Change.
DtNchangeFieldLabel specifies the label for the field in the Find/Change dialog box where the user specifies the replacement string. The default value in the C locale is Change To.
DtNcurrentLineLabel specifies the label for the current line number field in the status line. The default value in the C locale is Line.
DtNfindButtonLabel specifies the label for the button in the Find/Change dialog box that finds the next occurrence of the find string in the document. The default value in the C locale is Find.
DtNfindChangeDialogTitle specifies the title for the Find/Change dialog box. If DtNdialogTitle is non-null, it is added to the front of this resource to form the title. The default value in the C locale is Find/Change.
DtNfindFieldLabel specifies the label for the field in the Find/Change dialog box where the user specifies the search string. The default value in the C locale is Find.
DtNformatAllButtonLabel specifies the label for the button in the Format Settings dialog box that formats the complete document. The default value in the C locale is All.
DtNformatParagraphButtonLabel specifies the label for the button in the Format Settings dialog box that formats the paragraph containing the insertion cursor. The default value in the C locale is Paragraph.
DtNformatSettingsDialogTitle specifies the title for the Format Settings dialog box. If DtNdialogTitle is non-null, it is added to the front of this resource to form the title. The default value in the C locale is Format Settings.
DtNinformationDialogTitle specifies the title for the Information dialog box that is used to present feedback and general information to the user. If DtNdialogTitle is non-null, it is added to the front of this resource to form the title. The default value in the C locale is Information.
DtNjustifyToggleLabel specifies the label for the justify alignment toggle button in the Format Settings dialog box. The default value in the C locale is Justify.
DtNleftAlignToggleLabel specifies the label for the left alignment toggle button in the Format Settings dialog box. The default value in the C locale is Left Align.
DtNleftMarginFieldLabel specifies the label for the left margin value field in the Format Settings dialog box. The default value in the C locale is Left Margin.
DtNmisspelledListLabel specifies the label for the list of unrecognized and misspelled words in the Spell dialog box. The default value in the C locale is Misspelled Words.
DtNoverstrikeLabel specifies the label in the status line that shows that the editor is in overstrike mode. The default value in the C locale is Overstrike.
DtNrightAlignToggleLabel specifies the label for the right alignment toggle button in the Format Settings dialog box. The default value in the C locale is Right Align.
DtNrightMarginFieldLabel specifies the label for the right margin value field in the Format Settings dialog box. The default value in the C locale is Right Margin.
DtNspellDialogTitle specifies the title for the Format Settings dialog box. If DtNdialogTitle is non-null, it is added to the front of this resource to form the title. The default value in the C locale is Spell.
DtNtotalLineCountLabel specifies the label for the display as part of the status line that shows the total number of lines in the document. The default value in the C locale is Total.
Table 7-10 lists the class, type, default, and access for each of the localization resources. The codes in the access column show if you can:
Set the resource at creation time (C)
Set by using XtSetValues (S)
Retrieve by using XtGetValues (G)
See the DtEditor(3) man page for more information.
Table 7-10 DtEditor Localization Resources
Name |
Class |
Type |
Default |
Access |
DtNcenterToggleLabel |
DtCCenterToggleLabel |
XmString |
Dynamic |
CSG |
DtNchangeAllButtonLabel |
DtCChangeAllButtonLabel |
XmString |
Dynamic |
CSG |
DtNchangeButtonLabel |
DtCChangeButtonLabel |
XmString |
Dynamic |
CSG |
DtNchangeFieldLabel |
DtCChangeFieldLabel |
XmString |
Dynamic |
CSG |
DtNcurrentLineLabel |
DtCCurrentLineLabel |
XmString |
Dynamic |
CSG |
DtNfindButtonLabel |
DtCFindButtonLabel |
XmString |
Dynamic |
CSG |
DtNfindChangeDialogTitle |
DtCFindChangeDialogTitle |
XmString |
Dynamic |
CSG |
DtNfindFieldLabel |
DtCFindFieldLabel |
XmString |
Dynamic |
CSG |
DtNformatAllButtonLabel |
DtCFormatAllButtonLabel |
XmString |
Dynamic |
CSG |
DtNformatParagraphButtonLabel |
DtCFormatParagraphButtonLabel |
XmString |
Dynamic |
CSG |
DtNformatSettingsDialogTitle |
DtCFormatSettingsDialogTitle |
XmString |
Dynamic |
CSG |
DtNinformationDialogTitle |
DtCInformationDialogTitle |
XmString |
Dynamic |
CSG |
DtNjustifyToggleLabel |
DtCJustifyToggleLabel |
XmString |
Dynamic |
CSG |
DtNleftAlignToggleLabel |
DtCLeftAlignToggleLabel |
XmString |
Dynamic |
CSG |
DtNleftMarginFieldLabel |
DtCLeftMarginFieldLabel |
XmString |
Dynamic |
CSG |
DtNmisspelledListLabel |
DtCMisspelledListLabel |
XmString |
Dynamic |
CSG |
DtNoverstrikeLabel |
DtCOverstrikeLabel |
XmString |
Dynamic |
CSG |
DtNrightAlignToggleLabel |
DtCRightAlignToggleLabel |
XmString |
Dynamic |
CSG |
DtNrightMarginFieldLabel |
DtCRightMarginFieldLabel |
XmString |
Dynamic |
CSG |
DtNspellDialogTitle |
DtCSpellDialogTitle |
XmString |
Dynamic |
CSG |
DtNtotalLineCountLabel |
DtCTotalLineCountLabel |
XmString |
Dynamic |
CSG |
