Solaris 7 Motif: Based on The Open Group's Motif 2.1 with additional bugfixes and enhancements. The Solaris 7 software always includes the Motif toolkit.
The Solaris Motif library contains minor enhancements to Motif 2.1 usability to emulate certain OPEN LOOK user interface and Microsoft\256 Windows features. The usability enhancements include:
Optionally allowing mouse button 2 on a three-button mouse to be used to extend the current selection. This is equivalent to the OPEN LOOK Adjust function.
Allowing mouse button 3 to activate a CascadeButton menu (for OPEN LOOK compatibility).
Ability to re-map keybindings to be consistent with those for OPEN LOOK or Microsoft Windows applications.
Solaris CDE provides all the Motif 1.2.5 header files. The Solaris CDE libraries for Motif are the Motif 1.2.5 libraries with bug fixes and enhancements.
The Motif user interface language (UIL) is a specification language for describing the initial state of a Motif application's user interface. The CDE version of the Motif UIL library is essentially unchanged from the Motif 1.2.5 version.
Include the UilDef.h header file (found in the /usr/dt/include/uil directory) to access UIL.
The Motif resource manager (MRM) is responsible for creating widgets based on definitions contained in user interface definition (UID) files created by the UIL compiler. MRM interprets the output of the UIL compiler and generates the appropriate argument lists for widget creation functions. Use libMrm to access the Motif resource manager. The CDE version is essentially unchanged from the Motif version.
Include the Mrm/MrmPublic.h header files to access libMrm in your application.
See the OSF/Motif Programmer's Reference for information on UIL, the UIL compiler, UID, and Mrm.
