Solaris Common Desktop Environment: Motif Transition Guide
Convert and Clean Up
With small applications that have simple GUIs, you can practice porting by using a two-step process:
Chapter 7, Porting Example: OPEN LOOK to Solaris Motif, takes a simple OPEN LOOK application and illustrates this process.
Note -
This is not the recommended way to port large, real-life applications.
