Static Versus Dynamic Layout
As mentioned previously, porting your application to Motif is not an object-for-object swap. Such swapping concentrates on the static aspects of your application user interface. Complex applications in particular contain many objects that manage the application infrastructure and make it work in dynamic situations. (Dynamic aspects of your application include, but are not limited to, resizing windows, localization, and font changes.) These manager widgets that handle the dynamic geometry in your application are different in the OPEN LOOK and Motif toolkits. Your application will not display the dynamism you want if you try an object-for-object swap of manager widgets. Introducing an appropriate design to handle the dynamic aspects of your application typically
increases the complexity of its architecture.
XView does not provide much variety for dynamic layout. It primarily fixes objects at (x, y) positions, which can cause difficulties if an application font is changed or the application is localized. Motif and OLIT provide a variety of geometry manager widgets; however, they have significant differences.
Table 6-1 OLIT and Motif Geometry Manager Widgets
OLIT
Motif
Comments
BulletinBoard
XmBulletinBoard
Basically equivalent; provide static x,y pixel-based positioning for children
Caption
(none)
OLIT Caption widget provides a way to automatically place a label on one of the four sides of a control widget.
To get this functionality in Motif, create a separate XmRowColumn widget that contains two children: the label and the control
ControlArea
XmRowColumn
Both widgets provide a way to lay out children in rows and columns.
The OLIT ControlArea widget supports aligning Caption widget
children vertically by colon, which the Motif XmRowColumn widget does not. [CDE App Builder provides a geometry manager abstraction called a group that enables widgets to be automatically positioned in common layouts, including being vertically aligned by colon. App Builder generates all the code to implement this functionality.]
The Motif XmRowColumn widget enforces certain size policies on children (usually forces children in a particular row or column to be the same size), but the OLIT ControlArea widget does not.
FooterPanel
(none)
OLIT FooterPanel widget provides a way to lay out a window with a floating footer child at the bottom.
The Motif XmMainWindow widget can be configured for this layout by setting the "message area child" to be a widget that can be used as a footer (such as an XmForm or XmRowColumn widget).
Form
XmForm
Both widgets provide a means for attaching their children relative to each other and relative to the Form itself, however each takes a different view of these "attachments."
The OLIT Form widget provides attachment resources for the x and y dimensions, while the Motif XmForm widget provides separate attachments for all four sides (top, bottom, left, right). You can convert OLIT Form widget attachments to equivalent XmForm widget attachments if both attachment paradigms are well understood.
The Motif XmForm widget also provides a special type of attachment called "Position." Children can be attached to dynamic positions in the Form widget which change as the Form widget's size changes. This enables children to be configured to always occupy a certain percentage of the Form widget's real estate.
RubberTile
(none)
OLIT RubberTile widget enables children to be configured to take up a percentage
of the RubberTile widget's height (if vertically oriented) or width (if horizontally oriented).
In Motif you can achieve similar functionality by using the Position-based attachment resources in the XmForm widget.
ScrolledWindow
XmScrolledWindow
Both widgets provide a way to encompass a child widget into a scrollable view port.
(none)
XmMainWindow
Motif XmMainWindow widget provides a manager that lays out its children into specific areas of the window. These areas include the menu bar area, command area, work area, and message area.
OLIT has no equivalent widget.
(none)
XmPanedWindow
Motif XmPanedWindow widget provides a way to lay out its children in vertically oriented panes. Each of the panes has a sash that can vertically resize the pane.
