Solaris Common Desktop Environment: Motif Transition Guide
Widgets
Both the OLIT and Solaris Motif toolkits support a number of common widgets and gadgets with similar functionality, and each supports a number of more exclusive widgets. If a widget is implemented in one toolkit but not in the other, you can often build an equivalent object using multiple widgets in the other toolkit.
Table 5-4 matches the common widget name to the actual class name of the widget in each toolkit.
Table 5-4 Common Widget Mapping
OLIT Class Name
Solaris Motif Class Name
BulletinBoard
XmBulletinBoard
DrawArea
XmDrawingArea
ExclusiveChoice + RectButtons
XmRowColumn + XmToggleButtons (Radio Box)
Form
XmForm
Manager
XmManager
MenuButton
DtMenuButton (not accessible in OpenWindows environment)
NoticeShell
XmDialogShell + XmMessageBox
AbbrevMenuButton
XmRowColumn (Option Menu)
PopupWindowShell
XmDialogShell
NonExclusiveRectButton
XmRowColumn + XmToggleButtons (Check Box)
PopupMenuShell
XmMenuShell
Primitive
XmPrimitive
OblongButton
XmPushButton
ControlArea
XmRowColumn
Scrollbar
XmScrollBar
ScrollingList
XmList + XmScrolledWindow
ScrolledWindow
XmScrolledWindow
Slider
XmScale
StaticText
XmLabel
TextEdit
XmText
TextField
XmTextField
RectButton
XmToggleButton
Widgets Exclusive to Solaris Motif
This section briefly describes the widgets that are exclusive to Solaris Motif.
Note -
These widgets are also available for Motif development in the OpenWindows environment, except for the DtTerm, DtEditor, DtComboBox, DtSpinBox, and DtMenuButton widgets.
The libDtWidget library, which contains the DtComboBox, DtSpinBox, DtMenuButton and DtEditor widgets, depends directly on the following libraries:
Widgets Exclusive to OLIT
This section briefly describes the widgets that are exclusive to OLIT.
