Common Desktop Environment Motif provides two types of widgets that are not available in Motif 1.2.3:
MenuButton--A menu that doesn't need to be in a row column widget. Thhis was added primarily to help you port applications from a Microsoft\256 Windows or OPEN LOOK environment.
Terminal Emulator widget--Useful for applications designed to mix the best of a command-line user interface with a GUI
Editor widget--Available for embedding a more full-featured plain text editor than that available from the Motif Text widget
Help widgets--Handle navigation and interaction with application help volumes
Help is delivered with an application in the form of Semantic Description Language (SDL) files that have been compiled from HelpTag, a form of Standard Generalized Markup Language (SGML) files. The Help system features mixed text and graphics, hyper links, dynamic reformatting of text, and structured navigation capabilities.
