Common Desktop Environment: Style Guide and Certification Checklist
Window Decorations
y
n/a
n
Required
_
_
_
ab:
Windows that support particular window management functionality must request the corresponding window decoration (for example, a window that can be minimized should request the minimize button).
Required
_
_
_
ac:
Windows that support any window management functionality (move, resize, minimize, maximize, close, and others) must have a window menu with items for that functionality.
Required
_
_
_
ad:
Follow Common Desktop Environment window decoration conventions, as shown in Table 10-1.
Table 10-1 Common Desktop Environment Window Decoration Conventions
Border
Title
Menu
Min
Max
Resize
Primary Window:
Default
Front Panel
Yes
Yes [The Front Panel has custom visuals for the window decorations.]
Yes
No
Yes
Yes2
Yes
Yes
Yes [Decorations for resize and maximize should be provided for primary windows if appropriate.]
No
Yes1
No
Secondary Window:
Default
Front Panel
Yes
No
Yes
Yes
Yes
Yes
No
No
No [Secondary windows should be designed such that resizing and maximization are not necessary or appropriate. If a secondary window must be resizable and maximizable, the associated decorations should be displayed.]
No
No3
No
y
n/a
n
Required
_
_
_
ae:
Follow Common Desktop Environment window menu conventions. Items should appear in the window menu if they are applicable to the window or its minimized window icon.
  • Restore (R)
  • Move (M)
  • Size (S)
  • Minimize (n)
  • Maximize (x)
  • Lower (L)
  • Occupy Workspace ... (O)
  • Occupy All Workspaces (A)
  • Unoccupy Workspace (U)
  • Close (C) Alt+F4
Optional
_
_
_
af:
Applications should not add items to the window menu. If an extraordinary requirement has an application add items to the window menu, the items should be appended to the end of the menu with a separator between Close and the application items.
Optional
_
_
_
ag:
Accelerators, aside from Alt+F4 for Close, should not be used in the window menu (to minimize conflict with other uses of the Alt key for application accelerators, localization, and others).
