Common Desktop Environment: Style Guide and Certification Checklist
Window Placement
y
n/a
n
Recommend
_
_
_
ak:
Applications should not require or force windows or window icons to be positioned at a particular screen location.
Recommend
_
_
_
al:
A secondary window is placed by the application relative to the associated primary window. It should be placed close to, but not obscuring, the component that caused it to be displayed and the information that is necessary to interact with the dialog box.
Some suggestions are given in section 6.2.4.3, "Determining Dialog Box Location and Size," of the OSF/Motif Style Guide, Revision 1.2. Additional or modified recommendations include:
Optional
_
_
_
am:
If a dialog box does not relate to specific items in the underlying window, it should be placed below the menu bar (if there is one) and centered (horizontally) over the work area.
Recommend
_
_
_
an:
If a secondary window is allowed to be stacked below its associated primary window (not constrained to stay on top of the primary window), it should be placed such that it is not completely covered by the primary window. This recommendation takes precedence over other placement recommendations.
Recommend
_
_
_
ao:
If a menu or dialog box is already on display, reinvoking the command that caused it to be displayed automatically brings that window or menu to the front of the window stack without changing its position on the screen.
