Common Desktop Environment: Style Guide and Certification Checklist
Edit Menu Contents
Note -
These requirements apply only in a left-to-right language environment in an English-language locale. You must make the appropriate changes for other locales.
y
n/a
n
Required
_
_
_
6-8
If your application uses an Edit menu, it contains the following choices, with the specified functionality, when the actions are actually supported by your application:
Optional
_
_
_
Undo
Reverses the most recently executed action. The mnemonic is U.
Optional
_
_
_
Cut
Removes the selected portion of data from the client area and puts it on the clipboard. The mnemonic is T.
Optional
_
_
_
Copy
Copies the selected portion of data from the client area and puts it on the clipboard. The mnemonic is C.
Optional
_
_
_
Copy Link
Copies a link of the selected portion of data from the client area and puts it on the clipboard. The mnemonic is K.
Optional
_
_
_
Paste
Pastes the contents of the clipboard into the client area. The mnemonic is P.
Optional
_
_
_
Paste Link
Pastes a link of the data represented by the contents of the clipboard into the client area. The mnemonic is L.
Optional
_
_
_
Clear
Removes a selected portion of data from the client area without copying it to the clipboard and does not compress the remaining data. The mnemonic is E.
Optional
_
_
_
Delete
Removes a selected portion of data from the client area without copying it to the clipboard. The mnemonic is D.
Optional
_
_
_
Select All
Sets the primary selection to be all the elements in a component of the client area.
Optional
_
_
_
Deselect All
Removes from the primary selection all the elements in a component of the client area.
Optional
_
_
_
Select Pasted
Sets the primary selection to the last element or elements pasted into a component of the client area.
Optional
_
_
_
Reselect
Sets the primary selection to the last selected element or elements in a component of the client area. This action is available only in components that do not support persistent selections and only when the current selection is empty.
Optional
_
_
_
Promote
Promotes to the primary selection the current selection of a component of the client area. This action is available only for components that support persistent selections.
_
_
_
The use of an Edit menu with these common editing operations yields consistency across applications.
Recommended
_
_
_
bs:
If your application does not provide an <object-type> or Selected menu, but allows the user to select data within the window and manage settings for the selected data, then it provides a Properties ... choice as the last item in the Edit menu.
Required
_
_
_
6-9:
This item has been deleted.
