Common Desktop Environment: Style Guide and Certification Checklist
Window Management Actions
y
n/a
n
Required
_
_
_
aq:
Windows should follow Common Desktop Environment window management functionality conventions, as shown in Table 10-2
Table 10-2 Common Desktop Environment Window Management Conventions
Close
Move
Lower
Min
Max
Resize
Primary Window:
Default
Front Panel
Yes
No
Yes
Yes
Yes
Yes
Yes
Yes
Yes [Resize and maximize functionality should be provided for primary windows if appropriate.]
No
Yes1
No
Secondary Window:
Default
Subpanel
Yes
Yes
Yes
Yes
Yes
Yes
No
No
No [Secondary windows can contain the Maximum and Resize window manager functions, if appropriate. ]
No
No2
No
y
n/a
n
Required
_
_
_
ar:
Windows that support particular window management functionality should request corresponding window decoration (for example, a window that can be minimized should request the minimize button).
Required
_
_
_
as:
Windows that have form factor constraints need to set Window Manager hints for minimum size, maximum size, aspect ratio, and resize increment as appropriate.
Recommended
_
_
_
at:
Maximizing a window should show more content (objects or controls) if appropriate (as opposed to scaling up the sizes of objects and controls).
Required
_
_
_
au:
Windows that have Close or Exit functionality need to support the window management protocol for Close if there is a window menu. In the case of dialog boxes, the Close item on the window menu corresponds to the Cancel functionality or dialog box dismissal with no further action taken.
Recommended
_
_
_
av:
When your application creates a new window, it should come up in the user's current workspace and only occupy that single workspace.
Recommended
_
_
_
aw:
Application windows that are related to a particular task should move together between workspaces.
