Common Desktop Environment: Style Guide and Certification Checklist
Paned Window
y
n/a
n
Required
_
_
_
7-26:
If your application uses paned windows, they are composed of any number of groups of components, called panes, each separated by a sash and a separator. The panes, sashes, and separators are grouped linearly, either horizontally or vertically. A sash is the handle on a separator between two panes that is used to adjust the position of the separator.
This specification ensures the consistent appearance of a paned window across applications.
