Common Desktop Environment: Application Builder User's Guide
Draw Area Pane Property Editor
Only the one property unique to a draw area pane object is described here. See "Property Editor: Universal Properties" for descriptions of Object Type, Objects, Object Name, Initial State, and Color. See "Property Editor: Common Properties" for descriptions of Scrollbars, Border Frame, Geometry, Popup Menu, and Menu Title.
Total Canvas Size
Specifies the W(idth) and H(eight) of the draw area canvas. Note that only a portion of the canvas will be visible if the draw area pane's size is smaller than the canvas size (400 by 400 pixels, by default). You can use the scroll bars to view other parts of the canvas.
