Common Desktop Environment: Application Builder User's Guide
Draw Area Pane
Graphic
A draw area pane is used as a drawing or display area in the completed application. It is created by dropping a draw area pane icon on a main window, custom dialog, or another pane.
Note the horizontal and vertical scroll bars, which enable you to view objects outside the current view area.
Examples of the use of draw area panes in building App Builder include the panes displaying modules and module objects in the Module Browser, and the pane displaying modules in the Project Organizer.
