Common Desktop Environment: Application Builder User's Guide
To Edit a Message
  1. Choose Messages from the Editors menu of the App Builder primary window to display the Message Editor.
  2. Select the message you want to edit in the Messages list.
  3. Edit the message, as appropriate.
    • To delete a message, click Delete Message.
    • To modify the dialog box title, click in the Dialog Title text field and type the new label.
    • To change the message type, choose a different Type icon.
    • To modify the message text, click in the message text pane and type the appropriate changes.
    • To change the available buttons, select the check boxes and type new button labels, if appropriate.
    • To change the default button, choose another from the Default Button menu.
    • To modify help text, click Help Text, make the changes in the Help Editor, and click OK in the Help Editor.
  4. Click OK or Apply to apply the changes.
    The Message Editor will be dismissed if you click OK.
