Common Desktop Environment: Application Builder User's Guide
To Start App Builder from the Command Line
The command to run App Builder is dtbuilder. Do the following to start App Builder from the command line:
    Type dtbuilder
    If dtbuilder is in your path, App Builder will start. If it is not in your path, you will need to type the full path name (which, by default, is /usr/dt/bin/dtbuilder) or change to the folder where dtbuilder is located before typing dtbuilder.
