Common Desktop Environment: Application Builder User's Guide
To Cut or Copy Objects
  1. Select the objects you want to edit in the interface or the Browser.
  2. Choose Cut or Copy from an Edit or pop-up menu.
    Choose Cut or Copy from the Edit menu in the App Builder primary window, from the Edit menu in the Module Browser, or from the pop-up menu in either the primary window or the Browser (displayed by pressing mouse button 3 in the interface or the Browser).
    The chosen function (cut or copy) will be performed. If you choose Cut, the selected objects will be deleted from the interface and placed in the App Builder edit buffer. If you choose Copy, the selected objects will be placed in the edit buffer.
Choose Undo before performing any other function to cancel the cut or copy operation.
