Common Desktop Environment: Application Builder User's Guide
To Save a Project
A project is only saved when you explicitly choose to save it, so be sure to save often and regularly.
  1. Choose Save Project from the File menu of the App Builder primary window or Save from the Project menu of the Project Organizer.
    If you have saved the project before, the project will be saved without comment.
    If this is the first time you have saved the project, the Save Project dialog box will be displayed.
  2. Change to the appropriate folder.
    You will normally want a separate folder for each project you work on. You are apt to have Makefile problems otherwise.
  3. Type a file name in the Enter file name field.
    You do not have to append .bip to the project name; this is done automatically when you save a project.
  4. Click Save.
    The project will be saved.
