Common Desktop Environment: Application Builder User's Guide
To Remove a Module from a Project
When you remove a module from the current project, the module file will still exist in the project folder, but it will no longer be part of the project. The module file name will be removed from the project file (.bip suffix) the next time the project is saved. With the appropriate project open, do the following to remove one or more modules from the project.
  1. Display the Project Organizer by choosing Project Organizer from the File menu of the App Builder primary window.
  2. Select the modules in the module array that you want to remove.
  3. Choose Remove from the Module menu of the Project Organizer.
