In Test Shown Modules mode, all windows in the currently-shown modules will be displayed, including those whose initial state is not set Visible. See "To Test a Project or Selected Modules " if you want to test the entire project, with not-Visible windows hidden.
Display the module to be tested, if necessary.
See "To Show a Hidden Module " for instructions.
Click Test Shown Modules.
Click or press on the items in a menu bar, if appropriate.
The menus will be displayed. If you select a menu item that is connected to certain predefined functions (Show or Hide a dialog, Access Help Volume, Activate On Item Help, for example), the function will be performed.
Click each button menu, as appropriate.
Press mouse button 3 on a pane or list item to display a pop-up menu, if appropriate.
Click Build to return to build mode.
