In addition to the duties described in the section "Tasks Every ToolTalk-aware Application Needs to Perform" ," ToolTalk-aware editor applications also need to perform other tasks, including:
Declaring a ptype
Processing the start string message
Passing a media callback
Failing a message
Replying when a request has been completed
This section provides examples of the ToolTalk code you need to include in your editor application so that it can perform these additional tasks.
The code snippets used in this section are taken from the CoEditor.C file. This file contains specific commands for editor applications. See Appendix B, The CoEd Demonstration Program ," for the detailed source code.
There is one step you need to perform before you code your editor application to include any ToolTalk functions: you need to write a media load pattern callback routine. For example,
Tt_message CoEditor::loadISOLatin1_( Tt_message msg, void *pWidget,
Ttttk_op op, Tt_status diagnosis, unsigned char *contents,
int len, char *file, char *docname )
This callback is passed to the media load function at runtime.
Since type information is specified only once (when your application is installed), your application needs to only declare its ptype each time it starts.
The media load pattern callback routine you wrote previously is passed in at runtime. The callbacks are registered when your application joins the session. When your tool agrees to handle a request, a callback message is sent. A callback message is also sent if a file is joined or if a message is failed.
// Join the session and register patterns and callbacks
sessPats = ttdt_session_join( 0, 0, session_shell, this, 1 );
// Accept responsibility to handle a request
_contractPats = ttdt_message_accept(msg, CoEditor::_contractCB_, shell, this, 1, 1 );
// Optional task: Join a file (Can be called recursively)
if (_filePats == 0) {_filePats = ttdt_file_join( _file, TT_SCOPE_NONE, 1,
CoEditor::_fileCB_, this );
// Fail a message
tttk_message_fail( msg, TT_DESKTOP_ENODATA, 0, 1 );
After your application has completed the operation request, it must reply to the sending application. The following message returns the edited contents of text to the sender.
// Reply to media load pattern callback
// with edited contents of text
ttmedia_load_reply( _contract, (unsigned char *)contents,
len, 1 );
